Old 02-19-2009, 10:53 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default leaking pump jets / vented gas cap
Here is something I came across talk to someone. I am curious to know those of you that have a problem with the pump jet leaking after shut down have a non vented gas cap locked inside the Lehmans cap.
I was told to drive the car and when you shut it down to open the gas cap to see if this solves the problem.
It sounds bizzare but I can see how it may be the problem.
Also, what are you guys using to vent the tank if your not using a vented cap?
