Old 02-21-2009, 12:01 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Rick Parker View Post
When do you experience the popping? Part throttle? Cruise? Deceleration? Full throttle?
As above, when does it happen, what rpm at what throttle?
What's the settings of the carbs:
Venturi, emulsion tube, main, air, idle, pump jet, pump bleed, float level?
You really need a wideband O2 data logger to note the A/F ratio at the time of popping.
Gary
