Old 02-22-2009, 06:44 PM
Flat-Tyler Flat-Tyler is offline
Cobra Make, Engine: FFR1596
Factory Five Roadster.
I use a six inch lenght of two inch dia PCV pipe filled with activated carbon. I have a mustang fuel tank with a hose running out of the tank vent to the PVC. The PVC is tied onto my filler hose just under the body/fuel cap. One end has a nipple for the hose, the other is screw capped with small holes drilled in it, (think salt shaker.)
I shut off my fuel pump about 1/4 mile away and try to drain the carbs some before pulling into the garage when hot. If the car is cold it won't smell up the garage either way.
Hope this helps.
Frank
