Old 02-28-2009, 12:39 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by onefastmustang View Post
I actually already have a dial indicator and mag base for it. I have a piston stop as well. I guess I just need the degree wheel and a keg of beer...
Don't I need the softer springs or can it be done with the stock springs??
It will be easier with light weight checking springs, but it's certainly not a requirement. This is how I do mine:
If you decide to place the dial indicater on the rocker arm, you need something to prevent the hydraulic lifter from collapsing. Find a washer that will fit on top of the lifter, and then set the push rod on top of that. That will make it a solid connection.
