Old 03-14-2009, 12:46 AM
Mando's Avatar
Mando Mando is offline
Hi Baz, I was in the middle of installing all the stuff into the boot when I realized Id have to take everything out to install carpet. I then decided to remove what I had installed and paint the boot the same colour as the engine bay. I took the car to the painter last Tuesday. When it comes back Ill install everything in the boot which includes
fuel pump
battery cradle
2 main fuses
isolator switch
boot hoop
fuel tank filler
quick jack mounts
seat belt and roll bar cradle
boot prop
boot latch
This will allow me to install the fuel tank and connect the fuel lines which are already in place and the underbody exhaust once Gav has finished with the one he is using. My car will then go to the tuner to get it running. Once thats done its back to the painter to complete the exterior. I had intended to paint with the body of the chassis but its to hard. Then Ill be up to your stage of reinstalling the bling.
Everything on my car is made and ready to install. The only thing I need to get done will be the carpet and upholstering the seat shells.
Ill be happy if I get there by Christmas!
Regards.
Mando
