Old 04-02-2009, 12:02 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Ant
We use this filter on the pressure side.
http://www.cmfilters.com/remote_filt...il_filters.htm
It is 8 microns and the oil has to go thru it ...no by pass .... sealed on top and bottom..... and I can run the oil pressure as high as we want to ..... the pump is a Aviaid pump .....but we had a Cast iron pressure section made for it and the pressure stays stable at hige temps.
And we use the screen filters mounted in the oil Pan to the pump and then we use another one like this on the scavenge side out of the pump and to the oil tank.... both are needed, We take temps of oil in the Dry sump tank and we take temps after the cooler going back into the motor....
http://www.cmfilters.com/remote_filt...en_filters.htm
You can't protect your engine enough..... and our oil temps will go as high as 300*degrees and that is using the largest NASCAR Cooler made by Fluidyne.... Huge Cooler....
Morris
Morris
