Thread: What size carb?
Old 04-03-2009, 08:43 AM
wideglidejoe wideglidejoe is offline
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
I'd vote on the vac secondary. Light car, mech sec and dbl pumper, you'll just shock/overpower the rear tires that much easier. You can easily tune how fast/how soon the vac secondaries come in on the Avenger series Holleys by changing the springs in the vac module. Yeah, I've used mech sec/dbl pumpers, and they have their place.
I'm building an FE stroker to 455 cu.in., and I've got both 770 & 870 Avengers, I'll try both and see which works the best on mine.
I've also gave up on the Edel carb's; they're a good carb with a stock to mild cam, but once you get into a big cam, they're much harder to tune and get right, in my opinion (for whatever its worth?!?!?) compared to a Holley/Demon/etc.
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
