Originally Posted by Got the Bug
This is worth while. I had the funky platic line replaced when KCM installed the motor in 2715. The plastic line leaks at the fitting going into the motor on a lot of cars, as the fitting gets hot, and the engine torques up working the little brass ferrul into the plastic hose.
Don't ask why SPF does not give you the braided line from the factory.
If they did, you'd have no tinkering to do on your own.....
E
Bug, good post on the parts!
