Old 04-08-2009, 08:10 AM
McDoo McDoo is offline
Cobra Make, Engine: Former owner of Sp931
Originally Posted by Great Asp View Post
Post up some pic's of the gas tank you are having made please.
I'd like to see it installed (I like the looks of the stock tank) and how many gallons it holds.
Sump?
Baffles?
Eric 2715
Eric,
Fuel Safe has a custom tank that is configured to
fit the SPF in the same location as the factory tank. It is slightly wider than the stock tank so you need to do some fiberglass trimming in the inner fender area to fit it. It is Tig Welded aluminum with a sportsmen pro cell bladder. It
looks much better than the stock tank when installed, like
a polished SST tank. You should give them a call if I remember correctly it is somewhere around $1100.00. You will gain a few gallons of gas but gain a ton on safety
Mcdoo
