Old 04-11-2009, 05:36 AM
undy's Avatar
undy undy is offline
Default Dual quads finished, sorta happy
First off... kudos to BarryR and Quickfuel for working through the all the "tweaking" problems. These are Barry's new custom TrickFuel 750s that come built and setup for stroked FEs (around 482" or there about).
I ran the car on the chassis dyno yesterday and was a little disappointed in the numbers but hey, nothing that a 300 shot progressive fogger system won't cure Seriously, I'm thinking about it..
The engine's a typical 600hp Pond based 482 that Keith builds with a hydraulic roller cam. The neat thing about it is that while having a wide-band AFR setup hooked up to an inside mounted welded bung it maintains between 12.8 to 13.0 AFR during all part throttle and cruise... perfect! On the rollers it made between 12.5 to 12.8 AFR .. amazing and perfect. This is as they came out of the box from QuickFuel. It looks like Barry has these nailed! If you're looking for dual quads on your stroked FE I heartily recommend these..
Dave
Too many toys?? never!
