Old 04-17-2009, 05:01 AM
Question Did you check on the FE forum
cyclone427428 Rob the biggest bunch of FE pro guys are on the FE forum Dave Shoe, Royce, BB, and a couple of the other gray hairs will have the correct answers. What I have is a 63 406 motor with either tri power or 4 barrel. Valves should be 2.09/1.66. If you have a C2SE, that's a 390 head with 2.02?1.55 valves. These valves where used on 390, 428 motors. It's a small port head that would need some help to make any power for you. What are you trying to do or build?? The keepers may have been swapped for a valve job. Rick L.
