Old 05-03-2009, 11:55 AM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by DocDirk View Post
Fred,
The wiring is brand new on my car and it traces back from the sender to the gauge with the only narrowing being a grommetted 1/2" hole in my firewall. Connections are clean and the wire has no wear spots on it that I can see.
I'd never like to see oil behind my dash either now that I think of it. I'll order a VDO sensor replacement from JEGS.
Thanks again, you're most kind to this cobrabuilderwannabee
Dirk
The chances of a oil pressure hose failure are pretty low, especially if you use an AN line. The set-up you had was accurate, so it seems like a quick fix to try replacing the sender. Sounds like you're working the bugs out just in time for the prime driving season.
Doug
