Old 05-04-2009, 10:31 AM
Barry_R Barry_R is offline
Motorcraft gray silicone for use with 6.5-7.3 diesel engines - comes from the Ford dealer in a caulk tube. Clean all surfaces with abrake Cleaner or better yet with thinner. Put the silicone on both sides of the gaskets with your finger - as thin as a coat of paint - you don't want much. I glue the gaskets to the windage tray. A dab at the joints. Assemble with bolts that have the serrated underhead - available from ARP or Mr. Gasket - not studs - studs will loosen 'cuz you can't put enough clamp load on them to keep them tight.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
