Old 05-18-2009, 06:34 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by Bartruff1 View Post
occasionally coming from the right rear...I did a search, but too much data to sort thru... trunk is empty or is it a boot?...Shock bolts ok...this is not a bushing or a fiting or a rubbing and it is an occasional noise...it has been on a rack....much tightning and oiling.....has there been a common source that has been identified...the car is relatively new...2008 build ?? Thanks in advance for any clues...
Take a look and see if there is any contact at all between the trunk and the body of the car. Mine shows a little abrasion between the two surfaces, which causes a little rattle/clunk from time to time. I tried putting a very thin piece of mylar between the surfaces and it helped.
The other thing that you might want to look at is the sway bar mounts. Mine were make some noise and per Madmaxx's suggestion, I unbolted them and applied some dielectric grease and the noise went away.
May not explain the clanking noise, but a couple of things to look at.
Doug
