Old 05-24-2009, 05:22 AM
STEVE-O STEVE-O is offline
Originally Posted by efnfast View Post
now just wait until you want to start leaning how to compound and polish your paint to remove scratches, swirling, and micro-marring. Then the real fun begins
If you want to play around with a good washign technique, I'd recommend
1-2 big buckets with grit guards
http://www.autogeek.net/5gagrguwabu.html
good quality microfiberwash mitt
http://www.autogeek.net/cobra-blue-microfiber-mitt.html
poorboy's soap
http://www.autogeek.net/pbss128.html
4-5 waffle wave microfibres
http://www.autogeek.net/cobra-guzzler-hd-towel.html
You should be good to go. You really should do the rinsing with a pressure washer, but you can go an adequate job with a garden hose. Not the absolute most bestest job, but a decent job
Basically rinse, rinse again, then wash one panel/section per time, starting at the top and working your way down. When you get to the lower sections, make certain to really lubricate the areas to help move the dirty around.
Ohhh OK.. I knew this would eventually come to the point of selling something.
I'm sure autogeek also sells the foam sprayer attachment, clay bars, water de-ionizer blah blah blah....
This 'cobra owner' probably also appears in Porsche, Ferrari, Corvette and other performace car forums.
Good washing advice, but I have also seen it in Zaino documentation and other car magazines.
