Thread: Coil overs
Old 05-28-2009, 06:11 PM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
Originally Posted by maxum_101 View Post
thanks for the replys,
looking at my coil overs i dont see bilstein on them anywhere, they have the "superformance" name on the spring with some number and they are black. I called bilstein and the guy asked me what size, i tried to measure the larger ring and came up with 77.5mm. anyone know the correct size of these things? guy at bilstein said there was 2 diffrent size wrenches, i dont want to order a set and they be the wrong size.
also if i want to lower my front end, do i have to compress the spring or extend it?
The larger of the 2 sizes work best. Also you would need to extend or loosen the spring preload to lower the ride height. Don't go below 26" from the ground through the wheel center to the fender lip. It will mess up your camber setting too much.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
