Old 05-28-2009, 11:47 AM
Default Coil overs
hi all
i have car #2162 and was looking to buy the coil over wrenches anyone buy a set of these wrenches? if so where did you get them from? what size is the wrench?
any info on this would be great.
Old 05-28-2009, 12:41 PM
Banned
I use a Moroso unit that I got from Summit. It's adjustable and gets the job done, but sometimes it becomes a two hand process.
-Dean #747 (upgraded with Bilsteins)
Old 05-28-2009, 01:33 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
You can get them right from Bilstein. But remember, you need 2 - one to hold and one to turn.
SPFWiringDiagrams@Comcast.net
Old 05-28-2009, 02:23 PM
thanks for the replys,
looking at my coil overs i dont see bilstein on them anywhere, they have the "superformance" name on the spring with some number and they are black. I called bilstein and the guy asked me what size, i tried to measure the larger ring and came up with 77.5mm. anyone know the correct size of these things? guy at bilstein said there was 2 diffrent size wrenches, i dont want to order a set and they be the wrong size.
also if i want to lower my front end, do i have to compress the spring or extend it?
Old 05-28-2009, 05:04 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
The size isn't that important, I have a couple of different sizes and they all work just fine. Just get a set from Jegs or Summit and you're done.
" It ain't no big deal"
Old 05-28-2009, 05:11 PM
JCoop's Avatar
Cobra Make, Engine: Superformance, FRP460 Big Block
The larger of the 2 sizes work best. Also you would need to extend or loosen the spring preload to lower the ride height. Don't go below 26" from the ground through the wheel center to the fender lip. It will mess up your camber setting too much.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
