Old 06-03-2009, 09:10 PM
Heidelberg Heidelberg is offline
Cobra Make, Engine: Superformance (AUS 09 or SPF 2792) - LS7 427ci
Hi Baz,
I had a small stainless steel mounting bracket (about 3 mm thick, 200 mm long, and 12 mm high with 2 threaded holes at each end to line up with the licence plate holes) welded onto the underside of the lower bar of the oval front bumper that essentially positions a slim-line licence plate in front of the oil cooler.
The licence plate is mounted onto the mounting bracket with 2 "Allen-head" screws.
This works just fine for me for street use and if I want to do some track work, the plate is very easily removed to maximise air flow.
Regards.....Paul
