  #26 (permalink)
Old 07-04-2009, 07:13 AM
DMXF DMXF is offline
Original Shelby Owner
Cobra Make, Engine: 31XX Car
Default Cheetah exaggerations
Skid pad alone doesn't mean much as far as overall handling, it's just one parameter. From some internet searching on the Cheetah, following are some interesting tidbits:
"did quite well on the skid pad, it was concluded that the lack of torsional rigidity was responsible for the erratic handling."
"The handling was never widely acclaimed, however, and it was obvious that Titus’ skill was making up for a lot.....A local Chevrolet dealer picked up the sponsorship, and Titus raced the car briefly, but never with any outstanding success."
"A well detailed Cheetah was a beautiful machine, although it had a number of critical drawbacks in either everyday transportation or control on a race track. "
"The Cheetah was never really intended to be a race car.
Like most other Chevy specials, it’s primary purpose was to make money.
But to make money, it had to be produced as economically as possible, which meant few specially machined or welded parts."
"Practically every piece in the drive train, from the radiator back to the rear hubs was right our of the Corvette." This manifests in the flaws that many kit cars suffer from, in that you are taking suspension components designed to operate at certain points in space relative to one another and putting them on another chassis in different locations. Things like CG to roll center relationships and other parameters will never be just right.....usually only some things can be brought in while others are just what you end up with. The older Corvette rear suspension design is also far inferior to the upper and lower control arm Cobra rear suspension. Corvette racers from back in the day have told me the main way they overcame the suspension shortcomings was to use springs as stiff as possible to minimize suspension travel and of course tires as wide as possible.
The Cheetah also had drum brakes, which says alot.
The Cheetah appeared to have quickly created a bad reputation among drivers due to the poor handling......and there were many accidents as a result.
