  #26 (permalink)
Old 07-17-2009, 06:40 AM
patrickt patrickt is offline
Default My Problem is Obvious...
No.
It's a poor photo but the joint is well clear of the crossmember from below.
This is a shot taken from the trim ring hole with the shifter removed. It shows what I'm up against coming from beneath. I think with a long grease gun adaptor and one of those swivel gizmos at the end I can grease the u-joint through the trim ring hole, otherwise I'll pull the passenger seat out and install a trap door on the tunnel. Chas -- you did install a drive shaft safety hoop after snapping that picture, right?
