Old 07-22-2009, 06:58 PM
Rebel1 Rebel1 is offline
Mate, I'm not familiar with the Harrison chassis but you may have to consider moving the Centerline of engine to the right of centerline of chassis a little.
This in itself will give you a better alignment to your diff pinion flange anyways.
Then you may also consider raising the engine height a little ... say 6mm ... by putting a 6mm shim/washer under an engine mount.
Just a couple of things to consider before you start knotching that rail.
