08-07-2009, 04:38 PM
OR
You can get your spindles and rotors with caliper mounting brackets just about anywhere. Most of the suppliers will sell you the set up and delete the heavy GM calipers for a credit.
I used this set up, then bought the Wilwood GM Metric calipers as they are aluminum and saved about 12 lbs per side. They were pretty reasonably priced.
Check your pieces as soon as you get them so you can return them if you need to. I had my set up for a couple years before trying to fit them all up a couple weeks ago and the brackets wouldn't mount the callipers properly. It was too late to return them, so I had to modify them to fit.
