Thread: Primers
Old 08-18-2009, 05:05 PM
Danr55's Avatar
Danr55 Danr55 is offline
Tests have proven the Winchester are the hotest, followed by Federal, Remington then CCI. Generally, that means that you will get a higher pressure load with a Winchester primer than you will with any of the other if everything else remains constant. So if you develop a load with one of the slower primers, be sure to reduce that load before you change to one of the hotter primers.
Dan in Arizona
CCX3209
