Old 09-07-2009, 12:06 PM
undy's Avatar
undy undy is offline
I was looking the other day at the OEM radiator in my 07 Z06 and the tube/fin spacing is muck tighter than on the Griffin in the Cobra. With that said, I think with the "loose" fins and tube spacing the new Taurus fan should pull more than enough air through the core (hopefully). Of course, the proof will be in the pudding. For a "racing" radiator, per say, the HP rating is the most important factor for capacity rating since most "real" race cars never idle for prolonged times like our street driven Cobras do.
Dave
Originally Posted by vector1 View Post
i had to replace a radiator from howe racing. the radiator spec'd was rated at 400 hp by them from the info i gave them, i'm putting around 550 through it with an oil/water exchanger. hasn't been a problem yet. i asked if they could make the core tubes bigger and they said too big and it will not flow air, they only offered the one size. current size is either 1" or 1.125". i know griffin will make a larger core radiator cause i have one from them with the larger tubes. i think your radiator would be sufficient imo.
stewart/robert shaw makes good thermostats it seems.
Too many toys?? never!
