Old 09-11-2009, 10:53 AM
RedBarchetta RedBarchetta is offline
Banned
Default Post your SB Weber'd cam specs, please...
I'm trying to gather a consensus on cam specs for a Weber'd small block.
Please post the following:
Cubic Inches
Compression
Int/Exh lift
Int/Exh duration (@ .050)
Lobe Center angle
Webers used (IDF or IDA), and why
I'm currently running a stroked Windsor (392C.I.), 9.7:1 compression with a healthy Comp Cams hydraulic roller (540 lift int and exh, duration @ 240* Int. and 246* Exh. @.050, on 110* lobe centers). Been told this is too much duration for Webers to operate properly.
Appreciate the info, thanks!
-Dean
