Old 09-23-2009, 11:37 AM
Bobcat Bobcat is offline
Excaliber ... you mentioned there was no good way to run an MSD distributor at 20 to 24 degrees initial with the MSD 18 degree bushing . Almost correct . I`m running 26 degrees initial and a total of 36 degrees by using a 10 degree bushing from FBO in Cottage Grove , Oregon . Call Don there at 541-942-5920 . He makes 10 and 14 degree bushings for the MSD unit . You might also want to check out his website .... 4secondsflat.com .
You may have to open up the slot the bushing slides in some , but I didn`t have too .
Bob
