Old 10-04-2009, 06:48 PM
damdfw's Avatar
damdfw damdfw is offline
Cobra Make, Engine: CSX 4973
Joe,
Do you know if your Mustang transmission has the same input shaft as a TKO 600? If so, I have an input shaft. It is the BEST alignment tool by far.
Originally Posted by SSSammy View Post
Gonna be at Run N Gun, Joe. Use an alignment tool or an old input shaft to hold the clutch disk on center while you bolt up the pressure plate. Check the throw out bearing clearance from the diaphram (.15" - .30"). If it is a hyd bearing, be sure it is collapsed before measuring. Make sure the tranny is in neutral when you shove it up into the clutch. Don't force the tranny up. If it won't go up the last 1/2", you are not in the pilot bushing/bearing. You can crack the tranny housing and/or bend the clutch disc if you do this wrong. Ask me how I know ... Good luck!
Sam
David
