Old 10-16-2009, 04:50 PM
byroncobra's Avatar
byroncobra byroncobra is offline
Default EFI Connection & Sidepipe cutout
Gday fellas
Some advise please.....
1. How does one connect to the 3/4" male thread on the Mustang 302 EFI supply and return pipes? I'm running rubber 3/16 efi hose from a stainless barb on the end of the hard s/s lines and cant find a fitting to join hose to the threaded end.
2. I'm almost ready to paint with one hole left to cut in the body......that being for sidepipe exit. As i haven't yet purchased the extractor/pipe combo, can someone help me with a description of position and size of the cutout. I'm assuming that most extractors are about the same size.
Any advise on this combo would be appreciated. I hope to end up with working sidepipes after rego (QLD rego) and Warrick Harrison can supply a set of 'throw away' extractors at $500 which are designed to work with the underbody system, then i go back after rego pass and spend $1300 on 'good' ones to suit sidepipes. Any thoughts here?
Thanks
Greg
