Old 10-17-2009, 05:46 AM
Default Buy the after market larger fuel rails
byroncobra Bryon buy the aftermarket fuel rails and change the the dead end rail setup and have a loop setup for the injectors. Have 2 fuel filters on the system too. I know it's a pain to do but helps remove any small debrie from ending up in the last 2 injectors on that rail. It also helps cool the gas in the rail and doesn't let it overheat and cause boiling. Overbuild your fuel system also. A 255ltr fuel pump in the tank and min 3/8" to the front of the car and 5/16" return to the tank. If racing 1/2" and 3/8" this setup works the best and leaves room for you going to a larger motor down the road. There should be a simple bolt on kit for the rails. Look in the Mustang mags for this. If you have problems e-mail back will find you a company with the kit for bolt on. Saleen or BBK would be a good place to start. Rick L.
