Old 10-19-2009, 09:19 PM
Cobra #3170 Cobra #3170 is offline
Default Pulling to the right on acceleration
You have probably already checked this but can you physically move either rear wheel by grabbing it at 9:00 and 3:00 and try to get it to toe in and out?
I don't know what your rear suspension design is so this could be a non issue but Cobras that used a spherical bearing at the inner rear lower pivot can move if the bearing adjusting nuts are loose (for adjusting rear caster) or if the bearing itself has play in it. It does not take much movement to make a car do what you are describing.
Originally Posted by gthompson View Post
My car pulls to the right when i accelerate and the goes back to the left when i let off. Do all Cobra's do this a little or not at all?
Thanks George
