Thread: Wheel clearance
Old 10-31-2009, 04:37 AM
Rog246 Rog246 is offline
Originally Posted by 07cob View Post
Greg
The R32 camber arm has a 'ring' for the shock to pass through (ala the links Sambo supplied in your other post), while the R33 has a camber arm that runs around the front (or back - I'm not sure) of the shock. Given Merv's experience and yours, I guess the 32 and 33 rears are different widths.
Geof
Hi guys, I'm putting a R33 rear end in my Harrison & Warwick tells me that there is 10mm difference between an R32 & R33, with the '33 being the wider of the 2. Therefore I'm going to need adjustable camber arms to make it work. That was never going to be an issue for me as I have already bought all adjustable arms to I can adjust Camber,toe & caster as well.
Hope it helps
Rog246
