Thread: turkey pan
Old 11-10-2009, 11:54 AM
patrickt patrickt is offline
Originally Posted by fastd View Post
Patrickt (and others),
Have you noticed any difference after you installed your turkey pan? Would you say that it was "worth" it?
No, not really (and mine is easily removable so it's not a big deal to check). If I recall correctly, it wasn't so much the TP that limited performance a bit, but rather the smaller air cleaner that you then had to use. The K&N filter though seems to have lessened that impact quite a bit. There is a reasonably authoritative paper floating around, maybe on the SecondStrike web site, that analyzes all of that. Using a K&N filter with the TP gets you pretty close to the performance of no TP and a bigger air cleaner.
