Go Back   Club Cobra > Club Forums > AC Cobra
Old 09-28-2012, 11:42 AM
Default Need Classic Roadsters side vent inserts
I am looking for a set of side vent inserts for a classic raodster 427 please lead me to a set. Thanks Jim 903 485 2373
Old 09-29-2012, 07:24 AM
Cobra Make, Engine: CLASSIC ROADSTERS
Default C.R.Side vents
I have a brand new, never used set that are supplied with a Factory Five kit. They can be cut to the size you want. I'll let them go cheap or try Finish Line, Cobranda or any one of the supplier company's . They are not hard to find. You might have to do alittle reshaping of the size of the hole they go into, with these other vents.
Old 09-29-2012, 01:52 PM
Karl Bebout's Avatar
Jim, I think you'll find that the Finishline louvres are much heaftier than FFR's (unless FFR has stiffened their up). I used some industrial Velcro to mount mine and its nice to be able to easily remove them for some easier access to a couple spark plugs. I rivited pieces of angle aluminum to the louvers to have a good surface to attach the velcro. I also used some two part epoxy to attach the velcro to the body and to the angle. Maybe a little overkill, but better than running the risk of losing a louvre.
Karlos
Old 09-30-2012, 08:01 AM
jwoodard's Avatar
Thumbs up
Here's the link for the Finishline Louvers.
Finish Line Accessories
Jim Woodard
Old 10-02-2012, 07:16 AM
finish line lovers to big
Old 10-02-2012, 08:09 AM
The louvers don't fit inside the cut out, they are attached to the inside of the fender.
Karlos
Old 10-03-2012, 05:52 AM
Default Louvers from FinishLine
If you enlarge the cut-out alittle, they will fit inside of it and will look alot better and more professional .
Old 10-03-2012, 04:17 PM
If someone has a set of the CR vents and wants to send them to me, I will reverse engineer them in 3D solid model & make usable blueprints so anyone can have them made. I would return them when done of course.
I would not accept any $ for this because this is what I enjoy doing.
Terry
