Go Back   Club Cobra > Club Forums > AC Cobra
Old 02-04-2004, 06:40 PM
Cobra Make, Engine: B&B, 396W Southern Automotive Stroker, Custom 8.8 by Fabrication Concepts
Default body roll 2
I posted this note this morning on shop talk, but got no response. Hopefully my GA natives have the answer. I am getting tire rub on the drivers side and have the coil overs set 3" between body and tire. I really don't want to go any higher and wonder if anyone has had success with any of the kits advertised???
Thanks,
Matt
Old 02-04-2004, 09:30 PM
Junket's Avatar
Cobra Make, Engine: shell valley
Well Matt will give it a shot my guess is if you have that mutch room over the tire(if you have'nt got the coil overs at the max) the shocks are not stiff enough.
Talent is your head in communication with your balls.
Old 02-05-2004, 05:55 AM
Thanks, I am only 1/2 way down the treads on the coilovers. Not much experience with these so I am trying to figure it out.
Old 02-05-2004, 08:39 AM
Junket's Avatar
Matt you should have enough spring if it is not bottoming out with 1/2 left I belive that most Aldan shocks has a damper adjustment on them if that is the case turn the effect up that will slow the body role.
Ken
Old 02-05-2004, 11:21 AM
Send a message via AIM to cobrakit66
matt
my guess is the coil overs need rebuilding i went thru this myself with aldan coil overs, if theyre dropping the body to the tire set on #3 then they probably need a new seal
ron
cobrakit66
Old 02-05-2004, 11:53 AM
Clois Harlan's Avatar
Matt,
What rearend do you have in your car? Has it been narrowed?
Clois
"Let's roll"
"Be part of Something Good
Old 02-05-2004, 01:53 PM
Cobra Make, Engine: FFR1427
Matt - from personally seeing your car, I'm going to say it's one of two things (or conbination of both). Your rear end needs to be narrowed or you need wheels with a different offset/backspacing. It really looks like your wheels are sticking out too far, where they should be 'tucking in' under the wells better.
Old 02-05-2004, 04:41 PM
Thanks for all of the tips. I think Bud nailed it, as I didn't build the car, it has centerlines and a standard 9" that has not been narrowed. I am also going to check that shock setting.
Matt
