Go Back   Club Cobra > Club Forums > AC Cobra
Old 11-27-2004, 07:41 AM
Default Dacula Cobras?
I just bought a new house and moved into Dacula. I met someone a while back at McMichael Motorsports who has a Cobra and a landscaping business in Dacula. Does anyone know who this is?
Old 11-27-2004, 08:48 AM
marcocsx3121's Avatar
Cobra Make, Engine: Owned CSX 3121 1969-1975. Went to the dark side and bought a 'Vette. May yet repent and be saved.
Mike:
I can't help you with your hunt for the Dacula mystery Cobra, but I would like to know more about your engine. I'm contemplating get back into the Cobra thing, and my current wet dream centers on an FIA 289 (manufacturer to be determined) with a thoroughly over-powered Windsor stroker. I'd like to know who built yours, driving characteristics, dyno numbers, etc.
Thanks!
Old 11-27-2004, 10:01 AM
Marco, It would be great to blabber about my engine! The car setup stems from past autocrossing and winding mountain roads that I used to drive, my dream used to be to run the Chimney Rock hillclimb in NC before they cancelled it. I wanted an engine to be as light as possible with a broad torque curve. The max HP number isn't important. When I use a car in an autocross or road coarse, I find that it is a huge advantage to sometimes stay in a gear when you might otherwise shift, a car with better low end torque can be faster than one with a big max HP number. It is hard though to design an engine and force yourself to pick a slightly smaller cam etc.
I bought my block and rotating assembly from Kieth Craft and did everything else myself. I used Dynosim to determine valve timing.
Dynosim shows that it should be 536@6000 HP and 528@4500TQ . but I haven't dynoed it yet. I think it would be much less because I haven't yet had good headers made. Stock headers are limited by narrow bolt pattern, my AFR heads have an extra set of bolt holes further out to allow headers to match the port but I haven't found a supplier yet.
I wanted a durable engine that wasn't going to do stuff like bend pushrods.
The valvetrain is hydraulic roller and was actually somewhat designed around the valve springs. The springs are the new Comp beehive that have lighter pressure but better high speed bounce prevention. The valves and retainers are titanium. The cam is a custom Comp with 240, 244 @ .050. It has the fast acceleration ramps of a roller but gentle enough to be able to use the softer springs. The lifters are stock dogbone types that I modified the hydraulic travel to be much less. The have to be setup with care like a mech. but they don't have all that extra travel to create pumping up and collapsing. here's the engine specs:
Dart Alum block 4.125 bore
Eagle 4340 crank 4. stroke, Eagle H-beam rods.
Custom JE pistons 10.8:1
AFR 205 heads
Comp hyd. roller 240, 244 @.050 (set at 3 deg. retarded)
Victor jr
BG 850 carb.
MSD dist. 32 degrees total (also has 8 deg vacuum advance, 16 deg mech. , I could write a book on why I want it just that way)
MSD 6AL 6600rpm limit
Alum. flywheel with Mcleod street twin clutch, tilton hyd. bearing.
The engine seems to be a pleasant daily driver. It always starts right up, never gets hot and has good road manners. It's a given that any engine like this has power that can overwhelm the car. I measured gas mileage on a road trip and it was 18mpg hwy. It has been a sucsess beyond my expectations and it's almost boring because it just works well, except for headers, there's nothing more for me to do to it!
It would be a pleasure to meet up sometime, your vette sounds like somthing I'd like to hear about as well.
Old 11-27-2004, 10:09 AM
Tony Radford's Avatar
Mike, being a Dacula Cobra guy myself, the person whom you seek is Andy Peck. He owns Quail Hollow Nursuries over on Bailey Rd. He has a blue SPF with white stripes and a BB stroker. I can't believe Dacula has become a three-Cobra community. We're almost big enough to have our own chapter. There are probably a half dozen others we don't know about.
Old 11-27-2004, 10:35 AM
Mike:
Some interesting parallels between your Windsor and the LS6 Chevy in my Corvette. My engine is also 4.125" bore, 4" stroke, 11.1:1 C.R. The cam is a hydraulic roller 236/242/112 LSA, with .610" lift. The car dynoed at 528 RWHP and 520 RWT when it was built in late 2002. Recent advances on the intake side would give it another 20-30 HP. While the car is not emission legal (no cats), it is very streetable, and due to the efficiency of modern engine management coupled with the ultra tall 6th gear (.50 overdrive), I've achieved 26 mpg on the road and average 16-18 around town if I limit myself to only occasional insane blasts.
Your engine sounds like the one I'd build for my Cobra if I had one. I'd like to shoot for 500 HP at the wheels, which yours should approach with better exhaust breathing. I would love to see the car and learn more about the engine build. I'm only about 30 minutes away up in Gainesville: give me a call at 770-718-9885 and let's try to find a convenient time/place.
Mark Buchheim
Old 12-09-2004, 10:45 AM
Cobra Make, Engine: Superformance 514 stroker
Send a message via AIM to Andyqhn
Mike,
I think the guy your looking for is me. You got everything right except im in the greenhouse business instead of landscaping. I cant believe Dacula is becoming a Cobra town. That makes 3 I know of. There is a mysterious blue cobra i have seen on Dacula road lately, maybe Tony knows who that one belongs to. Welcome to Dacula, lets get togeather with Tony for a ride.
Andy
Old 12-10-2004, 12:20 PM
Hi Andy, I was thinking about planting some blue carpet juniper around my house. Could you supply that or do you specialize in commercial business? I did drive by and saw your greenhouses, wow!
Old 12-10-2004, 01:16 PM
Mike,
Were are open to the public but we only grow bedding plants. Come by and i can set you up with place to buy shrubs.
Andy
