| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
01-05-2005, 04:10 PM
GA
Cobra Make, Engine: B&B, 396W Southern Automotive Stroker, Custom 8.8 by Fabrication Concepts
351W heads???
I am looking to upgrade my cast world products heads with something new while I fix this cam/distributor gear problem. Any suggenstions on the best fit given stock compression, Weiand Stealth intake and cam with 534 lift/244 duration @.050. I like the Trick Flow heads but don't want to have to make custom headers or cut new pistons.
thanks for any input.
Matt
01-05-2005, 04:19 PM
Cobra Make, Engine: BDR 302 AFR 165
Go to Air Flow Research's site and check out the Articles. I would put the AFR 185's on it. I love my AFR heads best bang for the buck. I've never had TRick flow but several people in my area run them with good results.
Later Dennis
01-05-2005, 04:23 PM
GA
Thanks Dennis, I actually looked at those and the 205's.
01-08-2005, 08:18 AM
WI
Cobra Make, Engine: British Racing Green FFR, 302
MZHUN,
I am currently running Trick Flow twisted wedge heads on my 5.0L. I am very satisfied with their performance. With regard to changing headers it will depend on the heads you choose. If you use the TFS high port heads I believe you will indeed need new headers, however I was able to use my existing headers with the TFS twisted wedge heads.
P.S. Looks like we are in the same neck of the woods - Kennesaw, GA.
Greg
01-08-2005, 09:20 AM
GA
Cobra Make, Engine: FFR1427
Greg [/b]
How come we've never seen you? I get reports back from my fellow Officers on every Cobra spotted in the city. Newest one spotted here lately is a Red w/stripes and sometimes a Meatball.
Matt - the TWs should work fine on your set up. I have them as well.
01-08-2005, 10:02 AM
TX
Cobra Make, Engine: 68 GT 500 convt, 428 Cobra Jet
World Heads
Hey;
Are those the 2.00 heads ?
Why are you looking to upgrade?
01-08-2005, 11:15 AM
WI
SVOBUD,
I just moved back to Kennesaw. I lived in Kennesaw from 2001-2003. I spent the last year in Newport, RI. freezing my a$$ off. Actually I really enjoyed my time in Newport, great city with lots of history. Anyway Uncle Sam gave me the opportunity to move back to Kennesaw so I took it. Hope to see you and fellow ACC members on the road and at local gatherings.
Greg
01-08-2005, 12:10 PM
GA
yes, they are the Windsor R heads with 64cc chambers. i think i am gong to port and polish them instead.
01-08-2005, 01:58 PM
Ca
Cobra Make, Engine: Cutting Edge Replicas. 408 Stroker, Carbed.@550 H.P.
Look up Avenger heads on line & check out the new cyclone heads for fords. I think I'm going to give those a try. Chas
Take it out and stroke it !!!
01-08-2005, 08:06 PM
Don't count out Edelbrock I've seen that summitt had them on sale and they have been revised for better flow.
