Go Back   Club Cobra > Club Forums > AC Cobra
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-25-2006, 05:51 AM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Default Fuel filler hose
Did any of you Atlanta area builders get your fuel filler hose locally? I'm talking about that wire-reinforced hose that runs from the filler neck to the fuel tank. Mine is a couple of inches too short. One of the guys on another forum suggested a marine supply.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
Old 11-25-2006, 07:08 AM
Speedysnake's Avatar
Cobra Make, Engine: BDR - 351 / 385 hp
Tony,
I had to replace the two pieces on my BDR, long story, but I found 2" hose, rated for gasoline at NAPA, it isn't wire reinforced, but plenty tough.
Paul
Speedy
Old 11-25-2006, 07:38 AM
Karl Bebout's Avatar
I bought mine at NAPA and they sell it by the foot. Good stuff.
Karlos
Old 11-25-2006, 09:18 AM
Rick Parker's Avatar
Just make sure it is fuel rated regardless of where you buy it, some is used for coolant too.
Rick
Old 11-25-2006, 04:04 PM
Thanks guys. I found some at a local auto parts store (actual fuel hose). It was $1.75/inch. The hose that came on the car was a couple of inches too short. I've been able to make it work by centering it on the two necks and clamping it down tight. At least it came loose at the top as opposed to the tank. I've been smelling gas for months, thinking it was a rich carb setting. I noticed gas dripping from the back end of the car and upon investigation, saw that the filler hose was completely disconnected from the fuel filler neck. I guess gas has been sloshing out on hard cornering. I just took her out after replacing the hose and smelled no gas for the first time in ages.
