02-15-2011, 02:01 PM
Full Blown Member
Knockoffs
Autokrafters:
The Halibrand knockoffs (spinners) on my Compomotive (original to car) wheels are beat to sh!t.
I tried putting on a Trigo knockoff and if was TOTALLY different. The threads fit but the angle that the Compomotive wheels want are sharper than the Trigo. The contact on the 'knockoff to wheel' is minimal and it only spun on 2 full turns with lots of threads left over.
Any of you go through this?
rodneym
02-15-2011, 02:14 PM
Cobra Make, Engine: CSX 2252 sold 3-08, 1986 AC Cobra MK IV #185
No Problems with mine, approximately 6 to 7 thread turns on my spinners on the front, maybe 5 to 6 on rear. AC MKIV wheels were specialy built by Halibrand to specifically fit the AC MKIV.
I don't know much about the Compmotive wheel knockoffs. Good luck!
02-15-2011, 02:25 PM
Full Blown Member
Thanks for the reply, OldPhart.
We obviously have different wheels. Mine are 16", black coated centers, machined (and coated) lips, say 'Autokraft' on the front and 'Compomotive' on the back. They are not 100% accurate in their spoke style when comparing to Halibrands. The way they approach the hub is different.
The original Autokraft spinners, which ironically enough are Halibrand, fit the wheel and hub perfect. The Trigo spinner, which has the same dimensions as my Kirkham machined spinners, are the same, let's say original Cobra style. If you saw the original Halibrand spinner you might say they had additional machining. Where the conical area meets the back of the 3 ears has a sharp(ish) lip.
Hopefully I'll get some info from Hawk Cars, England.
rodneym
02-15-2011, 02:42 PM
Contact Gerry at Hawk Cars England
02-15-2011, 03:48 PM
Senile Club Cobra Member
Some early Mk IVs had Halibrands, all later 15s and ALL 16s are made by Compmotive for Autokraft. Most knock-off spinners have the ears foul on the wheel center boss before the spinner is on far enough to fully seat on the wheel. You must either flycut the back of the ears on the spinner or machine the center boss of the wheels to allow full seating.
Early MK IVs has an issue with the center lock nuts coming loose. Bob Negstad did a dye trace on his car and found that there was not enough interference angle on the wheel to nut. Bob said you need a one to two degree difference to get proper retention. Autokraft revised the nuts (the wheels were done in expensive pressure casting moulds and could not be changed).
rick@autoventureusa.net
02-15-2011, 03:56 PM
Full Blown Member
Mark IV,
I knew you'd have the answer.
I thought I was goin nuts.
rodneym
02-15-2011, 05:58 PM
MD
Why not just hold off until you get the new Halibrands....
www.partskeeper.com
02-15-2011, 06:58 PM
Full Blown Member
Different car.
rodneym
02-20-2011, 06:06 PM
Full Blown Member
Mark IV,
Gerry at Hawk cars said he was surprised the Trigos didn't fit. That leads me to believe that he may not know what you do about contact pitch/area.
And 595 pounds for a set!! That's $975 a set, plus VAT!
rodneym
02-28-2011, 02:24 PM
You can get out of VAT if you are shipping to the USA.
