| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
04-23-2008, 09:45 AM
AZ
Cobra Make, Engine: CSX 2252 sold 3-08, 1986 AC Cobra MK IV #185
AC Cobra MKIV motor mounts needed
Anyone know what kind of motor mounts or part #'s for a 1986 AC MKIV?
Perhaps a 1986 Mustang GT with the 5.0 H.O.?
Thank you.
04-23-2008, 10:52 AM
Senile Club Cobra Member
NY
Yes,
They are the Mustang units.
Rick
rick@autoventureusa.net
04-23-2008, 03:38 PM
AZ
Found them. Thanks, Rick!
Bill
04-24-2008, 08:18 AM
AZ
Cobra Make, Engine: Car builder/restorer FFR
There is a difference between coupe and convertable engine mounts. The convertables are better and I would recommend using those.
04-24-2008, 01:47 PM
AZ
You're right, Gordon. It looks as though the AC guys may have used coupe mounts, unless they were changed by the original owner before I purchased the car. The convertible mounts look way different and appear to not fit. The replacements I bought fit well.
Thanks for your help. You're knowledge is comforting.
Bill
04-24-2008, 02:28 PM
AZ
Both the coupe and convert mounts will bolt into the same place. The vert mounts tend to be about 1/4" lower. There is much less engine movement from a vert mounts.
04-25-2008, 03:31 PM
AZ
Hi Gordon.
Got both motor mounts to compare. The convert mounts have a "tab" on the back to the frame which may have to be shaved to fit. Hard to tell until I'm ready to drop the engine in. I hope there will be no problem with the oil pan (Canton drag race stock looking pan) clearance with the engine 1/4 inch lower. I'll try the vert ones first.
04-25-2008, 04:00 PM
Cobra Make, Engine: Ex CSX3327, & AK7113 AutoKraft AC MK IV
motor mounts
use the coupe mounts not the convt. thats how they were engineered.
04-25-2008, 05:03 PM
NY
There are aftermarket mount with Polyurethane instead of rubber, but what JBo said was right, the convert mounts are different as Ford needed to control NVH more on a ragtop. Even on the early (60s) Mustang converts, the engine mounts were different.
Understand that Brian did things based upon input from Ford and with the "flexi-flyer" AC frame, you don't want to tie the engine down too much as the loads will be fed into parts that were not intended to take such stresses.........
04-25-2008, 11:47 PM
AZ
Thanks, guys. I'll use what came on there originally, new coupe mounts.
07-19-2010, 01:14 PM
AZ
The Part Number for the Motor Mounts (from Checker Auto, Phoenix, Az.
PA 6318398 Motor Mount 2683 ($28.99)
PA 6318380 Motor Mount 2682
Reason: part no.
07-20-2010, 08:34 AM
That's correct. The PU mounts don't work. You can see the difference here:
with PU nearly no space to the frame:
with the normal rubber mounts much better:
Here both together not mounted:
