| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
01-02-2010, 05:05 PM
CC Member / Sponsor
Domed Filters for your TWM Injection
Squeaky wheel always gets the grease!!
www.gcperf.com
Reason: Update information
01-02-2010, 05:26 PM
Eight tiny air filters for your sleigh...
01-02-2010, 06:11 PM
AZ
I don't even have Webers and I'd love a set of those!!
Maybe a table center peice...hmmm.
01-02-2010, 06:26 PM
Az
Cobra Make, Engine: Black CSX 4910, Roush 511 8 stack
I can attest to the quality and fit and finish of these. I ended up with teh first prototype of these as no one else makes a proper filter that would fit under my csx hood with the 511 motor. Pricey yes, but absolutley beautiful. In the end I couldn't put a price on not sucking desert dust down those throttle bodies. I got mine in polished.
ron
01-02-2010, 06:27 PM
Very very nice. How much restriction do they have, or in other words how much hp lost. If I already didn't spend a small fortune on the roush ones you could sign me up. What is the going price? Beautiful
TX
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Is that foam under the screen or some kind of fabric and is material sandwiched between two screens?
Russ
01-02-2010, 06:33 PM
Those are very nice. I assume that they could also be anodized in satin black, semi-gloss black and gloss black?
01-02-2010, 08:53 PM
Absolutely Beautiful!
Regards.
Mando
01-02-2010, 10:21 PM
The entire setup looks great ... bet it looks even better under the hood of a Cobra !
01-03-2010, 10:22 AM
CC Member / Sponsor
These have the same material as a regular filter. I know that the filter element has been tested on what hp loss there was, but these had the best results. I'm not sure on the numbers but I will inquire about it. Anodizing could be in any style you wish. Color of the element can be changed as well.
Bill
www.gcperf.com
01-03-2010, 02:21 PM
Cobra Make, Engine: ERA 739
Who can I contact about these filters?
Kramer
01-03-2010, 03:54 PM
CC Member / Sponsor
contact me tomorrow at 859-630-9099 ask for Bill.
www.gcperf.com
01-05-2010, 04:58 PM
CC Member / Sponsor
Single place set of 8 billet hi flow filters with velocity stacks, screw top rings and black filters under stainless steel mesh. The filter material is a multiple layered cotton for high filtration.
Bill
www.gcperf.com
01-05-2010, 08:13 PM
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
These look like the filters made by C. Cook Enterprises in Kentucky. They were mentioned in a thread about two years ago.
I talked to them a month or so ago, and am considering getting a set for my IDAs. They are a bit on the pricey side.
01-09-2010, 09:04 AM
CA
Cobra Make, Engine: Cutting Edge Replicas, 427 World block SBF, TWM Injection
Beautiful! So, it sounds like you replace your old stacks with a new set of stacks (pricy in itself) and the new stacks have a screw on top for the filters?
What effect will these new stacks have on tuning with the manometer? (unscrew the filter and good to go?)
Bill - What's the cost?  I'm sitting down ...
 Ron; SF_SN888KE
Cutting Edge Replicas 427
Shell Valley Daytona #27
01-09-2010, 09:35 AM
CC Member / Sponsor
You are correct about the stack are swapped out. small block start out at 1250.00. You may want the low dome or high dome. That is why I would like you to contact me. There are a lot of variables in your decision. My number is 859-630-9099
bill
www.gcperf.com
01-09-2010, 04:53 PM
CA
Is there any effect on tuning with a manometer? e.g. unscrew filter and manometer fits as usual?
 Ron; SF_SN888KE
01-10-2010, 09:57 AM
CC Member / Sponsor
It will be the same.
Bill
www.gcperf.com
