Go Back   Club Cobra > General Discussion > Advertisers Forum
December 2025
Old 07-15-2010, 06:04 AM
Default B2 Motorsports 416FE, 431FE, 445FE Short Blocks Available
Custom made to order:
*Fully machined Ford 390 block: bored, honed with deck plates, square decked, align honed, cam bearings/freeze plugs installed, painted.
*ARP main bolts
*Clevite main & rod bearings
*Scat crankshaft (your choice of stroke)
*Scat H-beam rods
*Felpro rear main seal
*Probe forged pistons (your choice of flat top or dished)
*Total Seal piston rings
*Comp Cams custom hydraulic roller camshaft (based on your application)
*New cam thrust plate
*Ford Racing timing set
*Ford fuel pump eccentric (new)
*Camshaft degreed and installed
*ARP cam bolt
*PRW billet steel SFI flywheel, 11" Long pattern
*Professional Products harmonic balancer
*ARP balancer bolt
*ARP flywheel bolts
*Rotating assembly balanced
*Fully assembled with build sheet and build pictures
$4399
Options may be subtracted or added. Engine can be built to suit -- flat tappet cam instead of roller, flexplate in place of flywheel, etc.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Rate This Thread:
