Go Back   Club Cobra > General Discussion > Advertisers Forum
Like Tree12Likes
  #101 (permalink)
Old 05-23-2013, 06:36 AM
Jeff's heads are nearly completed. My porter is finishing up the details on the heads and has turned to the intake manifold.
The heads were pretty rough out of the box, but we were able to get some really stout numbers out of them.
337/341/347 j@ .650"/.700"/.750"
That's a smokin head for an FE.
The exhaust side came in at 260 cfm with a 2" pipe. That's phenomenal compared to any other wedge FE head out there that I've seen.
Jeff's cam lift is going to be between .650-.700" after lash, so the numbers at that level will support a good bit of horsepower.
  #102 (permalink)
Old 05-24-2013, 06:31 PM
Final numbers...
Intake flow
.100 70.00
.200 147.56
.300 217.62
.400 280.22
.450 303.05
.500 319.98
.550 329.79
.600 332.46
.650 336.92
.700 341.37
.750 345.83
Exhaust
.100 52.00
.200 109.68
.300 166.84
.400 217.06
.450 230.02
.500 238.44
.550 242.88
.600 245.87/with 2" pipe 262.41
.650
.700
.750 245.87
Check out the low lift flow numbers....and then check out the peak exhaust flow.
Sweet heads....
  #103 (permalink)
Old 05-24-2013, 06:45 PM
So 640 when all done?
Chas.
  #104 (permalink)
Old 05-25-2013, 06:19 AM
What's the port volume on those heads?
  #105 (permalink)
Old 05-25-2013, 06:24 AM
I don't have them in hand yet so I haven't checked them personally. My head guy says they are very close to a stage 2 KC head or survival motorsports' new head.
  #106 (permalink)
Old 05-25-2013, 04:19 PM
They are 208cc.
  #107 (permalink)
Old 05-26-2013, 03:06 AM
fordracing65's Avatar
Do you ever use there heads or do you always use a bare head and have your guy do the porting?
PRIDEnJOY
  #108 (permalink)
Old 05-26-2013, 05:24 PM
I buy bare heads and have them ported per application.
  #109 (permalink)
Old 05-26-2013, 05:43 PM
Dimis's Avatar
They are 208cc.
Ahhh... What does that actually mean?
OR should I say how does that compare to.. Edels, BTs, MR etc.
Thanks for the education.
  #110 (permalink)
Old 05-26-2013, 05:50 PM
Edelbrocks out of the box are 170cc.
That is the port volume of an intake port. When you port a head, it's sometimes necessary to significantly increase the port volume, just to increase flow. You are enlarging the cross sectional area. However, you can get to a point where the port volume is so big that the air/fuel charge will have velocity issues. The best scenario is a high flowing port with a smallish port volume. That will prove to be a highly efficient port.
Of course there is a balance to everything...
I'm suspect that some of the guys want that data for their engine sims. It proves to be fruitless for an engine sim though, because the intake manifold essentially makes up a portion of the intake port volume on an FE.
  #111 (permalink)
Old 05-29-2013, 06:05 AM
There are significant differences between my head and an Edelbrock or a Pond. All good parts, but all with different intentions and targets in mind.
I will pour one of JDC ported Survival heads sometime today if I get the chance. I have a set here that he had at a similar 340+ cfm. As cast with a valve job and bowl blend mine are at 180cc. Not sure how far Joe took these but it does not look all that big.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
  #112 (permalink)
Old 05-29-2013, 06:12 AM
I think Joe sent out the set that he had for the Aussie customer. He was the one that told me that the port volume all looked similar. He hadn't measured yours though.
Very curious to see how these do on the dyno. Should be strong performers, certainly better than the Edelbrocks on the chamber shape and exhaust side. Low lift numbers are really nice too. Joe put a nice backcut on the valves, so the charge should just slide right out.
  #113 (permalink)
Old 05-29-2013, 10:42 AM
just poured the intake port on the set Joe did for our Australia customer.
Intake volume is around 187cc - might be off by one or two but not much (damn thing dripped...)
Quite a bit smaller port than the Pond heads were.
Joe's flow numbers on these quoted for comparison:
"the heads are a solid 345cfm @ .700"/225 @ .650" and 254 with a 2" pipe
  #114 (permalink)
Old 05-29-2013, 10:55 AM
Well, since we're doing a comparison....
Robert's heads (from Joe Craine)
Lift Intake Exhaust
.100 70.00 52
.200 147.56 109.68
.300 217.62 166.84
.400 280.22 217.06
.450 303.05 230.02
.500 319.98 238.44
.550 329.79 242.88
.600 332.46 245.87, 262.41 with pipe
.650 336.92
.700 341.37
.750 345.83 245.87
Barry's heads (from Joe Craine)
Lift Intake Exhaust
.100 66.24 58.49
.200 140.01 103.99
.300 204.8 160.36
.400 270.08 199.24
.450 294.13 208.96
.500 309.73 215.44
.550 319.98 221.92
.600 329.79 226.78
.650 338.7 227.43
.700 347.61 228.72
.750 slight back up 230.02, 254 with pipe
Now granted, a 187cc port vs a 208cc port is a little different, but so are the flow numbers. A 48x inch motor is going to suck hard on anything you bolt on, so charge velocity isn't as critical.
I also don't believe the Pond heads will fit a smaller bore size, so we're limited to using these heads on the "big boys". Barry's heads should be 390 compatible.
At some future point, I wouldn't mind trying a set of your heads Barry if you would allow me to. I feel pretty confident in the Pond heads with these numbers though, especially at the low numbers and exhaust numbers. Proof will be in the pudding.
  #115 (permalink)
Old 05-29-2013, 11:31 AM
Awesome comparison...
PRIDEnJOY
  #116 (permalink)
Old 05-29-2013, 11:35 AM
Kinda hated that we did it right in the middle of Jeff's build thread though. Wasn't the best choice of venues.
  #117 (permalink)
Old 05-29-2013, 02:23 PM
Actually a fine place to have it. Probably be good to cross post this into the FE Forums as informational if you're cool with it.
Robert's heads were a good selection for this build - the bigger valve and the wide valve spacing fit the large bore - as does the large chamber. Backs up your selection criteria nicely.
More than happy to have you run a set once I get another pallet ordered up...
  #118 (permalink)
Old 05-29-2013, 02:28 PM
I'm fine with posting on the FE forum, and I have already shared the flow numbers over there, as you know.
If you wanna do a back-to-back, I think I have a candidate.
  #119 (permalink)
Old 07-15-2013, 11:26 AM
Sending some rotating assemblies out to have balanced this week, so I should be able to start mock-up on your engine this weekend.
  #120 (permalink)
Old 07-17-2013, 05:40 AM
Some more toys ordered last night...
PAC valve springs, Comp titanium retainers, locators, locks, Manley valve seals, blueprinted Melling oil pump, pump shaft, billet remote block adapter.
Got a good bit of prep work to do. CC & mill heads, prep work on block, mill carb flange on intake, etc, etc.
