Go Back   Club Cobra > General Discussion > Advertisers Forum
Old 01-17-2014, 08:07 AM
Default 408 Keith Craft Cobra Engine $9100.00
This engine is built, in stock & ready for delivery. This would make a great
addition to your cobra build. The horse power & torque numbers below are
from the dyno test on this engine. Call with any questions 870-246-7460
408 Street Crate
•Horsepower: 527 hp
•Torque: 539ft/lbs
•Block: Fully Machined and Prepped Production 351W Block
•Crankshaft: Eagle Cast Steel
•Stroke: 4.000"
•Connecting Rods: Eagle I-Beam 6.200"
•Pistons: Mahle Forged 4.030
•Timing Chain: Ford Motorsport Double Roller
•Camshaft: Comp Cams Custom Hydraulic Roller
•Lifters: Ford Motorsport Hydraulic Roller
•Cylinder Heads: CNC AFR 185
•Valves: Manley 2.02/1.6
•Rocker Arms: Scorpion 1.6 Roller
•Intake: Edelbrock Performer RPM
•Waterpump: Edelbrock Aluminum
•Carburetor: Quick Fuel 780cfm
•Valve Covers: Keith Craft Logo w/Breather
•Wire Looms: Smoothie
Oil Pump: Melling High Volume
Oil Pan: Moroso Front sump T-Style
•Balancer: Pioneer
•Ignition: MSD Distributor w/Keith Craft Logo Moroso Plug Wires
•Gaskets: Felpro
•Fasteners: ARP
Oil: 1 Case Joe Gibbs Hot Rod
•Compression: 10:1
•Fuel: Premium Unleaded Only
•Firing Order: 1-3-7-2-6-5-4-8
•Timing: 35 Degrees @ Full Advance
•Oil: 10w-30 or 15w-50 Joe Gibbs Hot Rod
•Max RPM: 6250
•Dyno: Full Test and Tune on SF902 Dyno
Keith C
