Go Back   Club Cobra > General Discussion > Advertisers Forum
Old 05-27-2007, 11:44 PM
Cobra Make, Engine: spf, stroked 460
Default need help with 17" PSE rims
question is about the way its sit on the hub. The car is SPF
and the rims are 17" PSE. Now there is about half inch space from the back of the rim and the rotor, it seems like the snout or the actual hole of the rim that sits on the hub the PSE is half inch shorter than the original hallibrand the car came with. Other than that it sits fine and you can tighten them good with the hammer. Did any of you guys run in to the same problem? Do I need a spacer to fill that half inch. Because Phil kne the rims were for SPF when I ordered them.
