10-03-2009, 04:52 AM
Fire Extinguishers
Over all the years I've had my Cobra, I've never installed a fire extinguisher. I've had a few carb leaks as well; guess I am lucky nothing ever caught fire.
On location, I take it the normal spot is between the seats on top of the transmission tunnel, and with the nozzle pointed forward so the latching mechansim is easy to get to. Although if it went off accidently, the cockpit would fill up possibly causing lack of visibility while driving. Hmmmm...not that likely I suppose, unless left out in the sun for an extended period.
But what size and type to run? I suppose ABC is good, but a 5 lb unit looks a little large, although better too much than too little I suppose.
For those of you that have installed a Fire Extinguisher, what type, size, location and orientation did you settle on?
10-03-2009, 05:47 AM
wa
You may want to consider a Halon system with nozzles in the cockpit and under the hood.
If you do a search you will find a number of threads with pictures that may help you out.
I believe that will be one of my Winter projects this year.
John Hall
10-03-2009, 06:15 AM
That's exactly what I installed.. six discharge nozzles under the hood, under the dash for the electrics/electronics and a nozzle in the driver's footwell..
Dave
Too many toys?? never!
10-03-2009, 07:23 AM
I carry two, both are chrome, and both are about 1.5lbs I think. The one behind the shifter, between the seats, is a fancy Halotron unit in case the fire is in my car. Supposedly it makes no mess; just don't breathe it. It also makes for an absolutely perfect elbow rest while driving The second one in the trunk is a regular ABC powder unit that makes a terrible mess if you use it. That one is in case the fire is in someone else's car.
10-03-2009, 07:43 AM
I had a chrome 2 pound one mounted between the seats and it has a quick release mounting bracket and also a pin to keep the handle from being squeezed accidentally. Took about 10 seconds to get it out and ready to use. I know this because they timed me once. But I would never have liked to had to have used it. Really more for looks than practical use.
10-03-2009, 08:04 AM
That one statement describes my entire car.
10-03-2009, 08:39 AM
Patrickt,
I think it pretty much describes most of these cars. I guess the Coupe would be ok to drive in the rain except for the traction problem. It has a full fire suppression system in it to pass inspection at the tracks. But it is not a practical car by any means. Just fun.
10-03-2009, 08:40 AM
I carry 1 of each type as well, but for different reasons. The Halon, Halotron or Halguard type extinguisher is the one to use first. However, there are many circumstances where they won't be effective so you want a dry chem. as a back-up.
The pre-plumbed systems look cool but their purpose is to only control the fire long enough to allow the driver to get out so he can get a good view of the car burning to the ground. I would take 2 hand held extinguishers over the best pre-plumbed system on the market.
10-03-2009, 08:56 AM
Well....a very diversified plethera of replies. Thank-you.
10 seconds? I can see that for me....1 second to free the extinguisher and 9 seconds to get out of the car while holding it.....not to mention getting the hood open. But most engne fires start out small, at least the ones I've had (not in the Cobra). The idea is to get to them before they spread.
Some of the brackets are really wall brackets and wouldn't hold a bottle terribly securely. Have to look into what's available.
Halon. Dopey military put them in our submarines. That's nice if the system goes off. Probably asphyxiate everyone on-board. I hear it isn't good to breathe in, nor is it popular with the ozone-saving public, although hopefully one would never use it, so the ozone layer (and me) would remain safe.
Manaul vs plumbed system. From the number of fire extinguisher training courses Ive done, it certainly is apparent that where you aim the extinguisher has an awful lot to do with getting the fire out succesfully, so manual is fine for me.
As far as having one, I wasn't conerned about it being a cosmetic addition. I read in another post how the youngsters figure it's a NOS bottle. Now how could they get that confused?????
I see I have a 2.5 lb unit in my kitchen which looks a decent size. A similiar one, probably ABC might be a good idea. Now red, orange or blue?
Thank-you for your replies. Time to visit the hardware store and see what they have.
10-03-2009, 09:09 AM
Me
That was one piece of equipment I installed right from the getgo.Mine is mounted behind the shifter and instantly available in or out of the car.
10-03-2009, 09:20 AM
10 seconds? I can see that for me.....
There are damn few things I can do in 10 seconds (now I know RodKnock is going to bust my balls with a straight line like that) but I think if my car was on fire I could get out and touch off one of the extinguishers in that amount of time.
BTW, that's a nice shot of Evan (REAL1) in my car up above in my first post. Yes, he dropped by and wanted to sit behind the wheel of a mechanically superior, albeit fake, Cobra and I just couldn't say "no."
10-03-2009, 09:38 AM
Regarding the picture, do you suppose he's saying, in the words of Jacques Cousteau, "I am aghast...."
Poor Evan. I like him. I'm sure he is as proud of his car as I am of mine. I wonder what he uses for a fire extinguisher?
10-03-2009, 09:53 AM
I like him too -- and I would probably hire him as well. I have no doubt that if I told him to march in to a meat grinder he would salute smartly and head right in there. That's the type of work ethic I look for.
10-03-2009, 10:04 AM
ID
Cobra Make, Engine: Contemporary Classics 427 SC, 427 sideoiler
I drove my car for a number of years w/o an extinguisher. Two weeks after I installed a 2 1/2 # Halatron between the seats, I had a fire. I know I had the Halon going within 10-20 seconds, but a lot can even in that time. Luckily, the under side of the hood and scoop are polished aluminum and it saved the paint. It took the wires and fuel lines and made it mess. But, it did clean up.
Don't leave home without one!!!
10-03-2009, 10:06 AM
What was the cause of your fire?
10-03-2009, 10:13 AM
I now seem to have a lot of information. There's a Fire & Safety Supply business close by. I think maybe I'll go talk to them. At least now, I can speak more knowledgeably about it when I go see them.
This is a great site. I now have info on brake upgrades, rev limiters and fire extinguishers. All good winter projects, as long as I don't have to brake hard, have a fire, or over-rev the engine before then.
Not to mention all the help when my engine wasn't running right. Good or bad,I apprecaite those who helped or tried to help. Thank-you.
10-03-2009, 10:17 AM
You know I think of Nova Scotia as being on the Arctic Circle, but I guess if you're in the southern region then you're really not much further north than Concord.
10-03-2009, 10:25 AM
ID
The root cause was a loose fuel line Patrick. But it was kind of a domino thing. It has a BG Demon w/o a choke, so it loads up when started up cold. When I cranked it, it coughed or backfired thru the carb (never does this). Within seconds, it started dropping cylinders and I shut it down. That's when I noticed smoke rolling out he scoop. It turns out that the carbon button on the inside top of the distributor disinigrated causing the spark to run wild under the cap triggering the backfire. S*** happens quick.
10-03-2009, 12:23 PM
wa
I'm curious about the statement regarding plumbed systems. While I agree a plumbed system cannot be aimed, they are used on a lot of race cars and seem to function there. And specifically on the NHRA Funny Cars with their systems.
Am I'm missing something Jim?
John Hall
10-03-2009, 12:39 PM
