Old 10-07-2009, 06:28 AM
Cobra Make, Engine: SPF 2592, Shelby alum. 527
Originally Posted by TButtrick View Post
I don't think anyone would tighten the belts so much that it would compress their spine but wouldn't the roll bar attachment allow more vertical slop if you rolled? I've often wondered why this is done at all. I'd rather be cinched down tight in the car in any type of accident
From: http://www.circletrack.com/techartic...ion/index.html
"The end attachments of the shoulder harness must also be installed at appropriate angles. The ideal position is anywhere between five degrees below and 30 degrees above the driver's shoulder.
If the upper attachment point falls significantly below the driver's shoulder, then a spinal compression injury is likely to occur. In an accident, the shoulder belts pull down and back on the torso as they resist the forward motion of the driver. The resultant restraint force compresses the spinal column and will add to the stresses in the spine already caused by the force of the crash impact."
This has been discussed here before.
Rodger
Old 10-07-2009, 06:30 AM
Cobra Make, Engine: SPF 02345, Roush/Yates 358 Sprint Cup motor
That is correct, in an accident if the belts are too low you could unnecessarily injure your spine, it is better to mount them to the roll bar.
BOTTOM LINE is unless you have a roll bar, properly installed seat belts AND wear a helmet you run a higher risk of injury.
I don't think anyone would tighten the belts so much that it would compress their spine but wouldn't the roll bar attachment allow more vertical slop if you rolled? I've often wondered why this is done at all. I'd rather be cinched down tight in the car in any type of accident but I do see your point regarding being able to duck.
Old 10-07-2009, 06:42 AM
TButtrick's Avatar
Well said.
Display Modes
