November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-14-2009, 08:40 PM
Default Carb ????
After driving the car today for 20 miles or so it started to stall out when I came to a stop. Had to put it in neutral to keep it running. I have a 351w automatic with a Holley 4160 4 bbl. What could be the problem?
Old 11-14-2009, 08:50 PM
JA COBRA's Avatar
Cobra Make, Engine: superformance 460/ stroked to 521
Does the car start and run now? I had the same problem a while back and it turned out to be a distributor. the wrist pin let go and the gear was loose,timing was off and car started stalling coming to stops.
Old 11-14-2009, 09:25 PM
The car starts fine. This is something that started today.
Old 11-15-2009, 03:24 PM
Cobra Make, Engine: 351 Windsor
I wonder if advancing the timinig would solve the problem of stalling or increase the idle??
Old 11-15-2009, 04:20 PM
Will it idle at all if you take your foot off the pedal and put the trans in neutral?
If not, either your timing got retarded somehow, or you might have some debris in one or more of the idle jets.
Does the car accellerate OK? If so, not the dizzy or the main jets.
Jim
Old 11-15-2009, 05:44 PM
209 209 is offline
Cobra Make, Engine: Superformance 2765 Roush 427(POS) with cruise.
Hello Pacco,
Kinda cold in Ohio, no? It reached 60 here in central Cal but nice! Did alittle 30 mile run today just to visit. Hope you find your problem. 209
Old 11-16-2009, 03:22 PM
Frank Messina's Avatar
Cobra Make, Engine: FFR, V8, Manual Trans, Htr, Wipers, Radio Delete
Check for a vacuum leak.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
Old 11-16-2009, 03:41 PM
rokndad's Avatar
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
Sounds like a float issue. Do a search on Holley floats and you will see many, many threads about the stalling issue with floats. You'll learn all about "whistles" and sight glasses and other things you can try. Your float may be stuck, the needle stuck or various other things. I could never get my Holley to not want to stumble on a hard decel. So I went with Webers!! Best of luck.
Old 11-16-2009, 04:10 PM
ZOERA-SC7XX's Avatar
I've experienced similar problems from time to time. I actually fouled (gas) out a plug or two on a couple occasions under spirited driving conditions. The fouled plug would rectify itself with mild driving. I think my carb is just too much for the engine. Doug at ERA told me to reduce the jet size in increments of two until I get it right. I also checked and adjusted the float level. My carb is a Holley 750 vacuum secondary. I'm gonna try the jet replacement and see what happens.
Old 11-16-2009, 04:26 PM
mrmustang's Avatar
Gold Star Contributor
When is the last time your points, plugs, and wires were changed? I had an issue with my ERA last year when I first got it, changed out the aged sparkplug wires, points, and plugs and never had a problem after that. While the plug wires looked fine, as soon as I touched them they cracked with age.
Bill S.
