| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
01-20-2008, 02:44 PM
What are you using for rear rollbar tube grommet?
I just installed my rear rollbar tube. I tried using a slit fuel line slit lengthwise around the unfinished oblong hole, but I don't like the way it looks. It's too heavy and bulky looking. I don't want to just leave it untrimmed. Is there any light thin "U" channel type stuff any of you have used and can recommend? I've seen the stainless and/or aluminum and rubber type grommets that are sold that mount above the rear deck of the car and I don't want to go that way. I'd like something rubber that wold be used similar to the slit fuel hose method, just less bulky and neater looking.
01-20-2008, 02:50 PM
ca
Mike Z
01-20-2008, 03:41 PM
NH
Doug,
Via Cobra Restorers:
For strut opening, use split vacuum hose and knife edge body.
I use nothing as the hole is clean and neat anyway. You are repainting so why not edge and smooth. The paint will create a nice rolled edge look and stay with the theme of these cars "Utilitarian".
Rubbers are overated anyway!
01-20-2008, 04:17 PM
I like the look of a clean edge and no rubber. Unfortunately the hole turned out to be just a bit larger than I wanted. It's not bad at all, but is a bit larger than yours. Also, for reasons I don't understand, the paint chipped a bit around the edge. I was real careful with it, made sure I used a fine tooth hole saw from the top, etc, but it still chipped up a bit.
Mike, the ones from Finishline mount on top of the deck, not was I was looking for. Thanks for the info, though - I appreciate it.
01-20-2008, 04:32 PM
wa
Go to the link below and type in "Edging", or go to page 3655 for Edge Trim. They have a lot of other types of trim also.
McMaster-Carr
12-14-2009, 06:36 PM
NH
Slit tube super glued together at the ends.............
12-14-2009, 07:37 PM
Senior CC Premier Member
CA
This is what I used from Finish Line....
12-14-2009, 07:44 PM
NH
I've also used them but only when someone had done the hole before me and I needed a big cover up. That back one is a trick with them isn't it?
12-14-2009, 07:58 PM
CA
Yes, a trick to be sure. Catching enough meat for the srews and working with an oblong hole.....Someone else had made them too big, so that's the route I went. Looks like my pic didn't come out. It's in my gallery if someone needs to see it.
12-14-2009, 09:25 PM
Ca
Thin wall radiator overflow tubing (plain rubber, non re-enforced) works very well. Slit it in a straight line.
Rick
