November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 12-30-2009, 07:56 AM
Silverback51's Avatar
Default Seat Heaters
I was trying to decide between seat heaters, or buying heated vests. Looked at some heated vests yesterday and decided they are bulkier than what I want to pack up when not in use.
So, does anyone have any recommendations regarding seat heaters? I'm looking for the type that are installed under the seat cover, not the cushion type that can be removed.
Thanks in advance.
John Hall
Old 12-30-2009, 08:15 AM
Blittleton's Avatar
CC Member / Sponsor
I have used these several times with my customers. website www.cobraheat.com sales@warmseats.com
The best I have installed so far.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
Old 12-30-2009, 08:24 AM
jwd's Avatar
jwd jwd is offline
John, I have the ones from Cobraheat. They work great.
Jim
Old 12-30-2009, 08:33 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
You have a PM regarding the seat heaters...
SPFWiringDiagrams@Comcast.net
Old 12-30-2009, 08:51 AM
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
I use these with Kirkey aluminum drag buckets. I merely sliced the foam of the seat cover away from the material and inserted them. Then the heat produced is insulated from the aluminum heat sink by the foam. Toasty. Below 10 degrees F, you will start to wish for more unless you put the top on. Even then it is only an issue above 70 mph. I do suggest you put them on a relay to prevent accidentally leaving them on.
Old 12-30-2009, 08:23 PM
Default they work great
Bill
Hey Bill, those seat heaters from that company work very well, I have them in my car, they come with every thing you need.
Old 12-31-2009, 10:59 PM
Stinson Pilot's Avatar
Cobra Make, Engine: FFR MKII #3133 3:27 Pin Width IRS, Carb'd Explorer 302 w/GT40P Heads, 3550 Mid Shift, Power Brake Mod, 15" Torque Thrust D's
John, I went for a drive the other night. It was maybe 38* out. I don't have my heater connected yet, but the CobraHeat seat heaters sure felt good.
I'm also getting a set of these with gloves. It's the jacket liner and it's not bulky: http://www.gerbing.com/Products/Line...cketLiner.html
Rattlesnake Lake:
Doug
Old 01-01-2010, 09:24 AM
Cobra Make, Engine: KMP-216S Kirkham Street '66 428 PI
My heater says Ford on the valve covers.
K
