01-07-2010, 08:46 AM
Continuation Shelby frames
In the new book about Shelby cars, there is a page on the continuation Cobras. As the text is kind of slipshod and there are no relevant pictures, this sentence confuses me: (from memory) "As the fiberglass body has to be bonded to the frame, the front and rear subassemblies are bolted into the continuation cars instead of welded as in the original."
Does this mean the continuation cars do not have a one-piece frame? Or that the suspension assemblies are bolted in as units? Or what? And is the same frame used in the aluminum cars?
01-07-2010, 09:43 AM
No, it is not.
01-07-2010, 09:57 AM
Cobra Make, Engine: KMP241 427 S/C 482 Shelby
Gunner,, having dismantled a fiberglass csx4000 car, the only bolted, instead of welded structure was the square tubes which run from the front cross member to the upper cowl hoop. The body is rivited to the frame & upper structure, I guess thats what they mean by " bonded ". The rear cockpit hoop was changed to accomadate the fiberglass body, and interior tub. I'll add pics to my gallery......Ron
RON N BKFLD
Reason: wording
01-07-2010, 10:12 AM
I find it funny that the Kirkham guys are answering this.
Thanks, though. I think this is another area of the book where the author got in over his head and faked his way out. He should have stuck to pictures and lists.
01-07-2010, 10:24 AM
...we know that you are easily amused.
01-07-2010, 12:28 PM
IA
Additionally, the top half of the cowl hoop is bolted on as well as the structure around the trunk (boot) opening. It is recommended that these be welded as part of the final assembly procedure.
Nothing is "bonded", as Ron stated above.
01-07-2010, 12:31 PM
Cobra Make, Engine: CSX Cars
Some nice cars under the continuation section!
A happy SAI customer
Cobra Make & Engine: Continuation Series Shelby Cobra, CSX 7034 the most accurately detailed Continuation Cobra to original specification since the demise of CSX 4027.
01-07-2010, 12:44 PM
How many corrections did you make with your red pen? I guess the publisher didn't contact you to edit the book.
Doug
01-07-2010, 01:14 PM
LA
Cobra Make, Engine: CSX4083, NOS 427 SOHC, serial number 589. Dyno'd in 1967 at 629HP with single 4v 560 Holley. Now with 4 Webers.
CSX4083 getting mods for SOHC motor with body off in 1998:
Alan Sorkey
Shreveport, LA
01-07-2010, 01:27 PM
I gave up correcting nonessential books years ago, although I will fix grossly misstated facts so as to prevent confusion.
Most books of this type are edited lightly, if at all. A spell-check of the electronic ms file and a read-through by a junior editor is about all it gets.
The book would have been far better had a real editor been involved early on to steer the author into a more consistent, fact-driven and less folksy style.
01-07-2010, 03:25 PM
DougD,,,,,,,I can only speak about CSX47XX, Mexico built. I completly dismantled to bare frame. only bolted bird cage or main frame parts were as I stated in earlier post. I don't doubt that CSX4068 is as you discribe, like the current south africa cars are most likley different as well. I said bodies were rivited. Original post said "bonded".
The CSX I bought did make a good parts car for my Kirkham 427......Ron
RON N BKFLD
01-07-2010, 04:00 PM
Stolen Avitar
GA
Now THAT cracks me up!! Perfect!
01-07-2010, 04:06 PM
I have heard that these cars have a number of changes between the glass and ally frames. Rear clip is different, both discrete tubing under dash and cowl are differnt so the one part body can slide into place.
As stated, probably differs between generation of car and country of origin?
01-07-2010, 04:42 PM
There are differences between South African cars and Mexican cars. The bolt on birdcage tubes either side of trunk are so a one piece glass trunk can be installed. Cowl brace tubes bolt in so footboxes can be removed and installed. Oil cooler brackets bolt on so glass body can be put on over nose. Some front bumper brace tubes bolt to the front of the frame rails for the same reasons. Need pictures or details of something specific let me know.
01-07-2010, 04:57 PM
It would be interesting to note the differences with the Las Vegas CSX's too.
01-07-2010, 08:33 PM
Az
Cobra Make, Engine: Black CSX 4910, Roush 511 8 stack
Pkease forgive my ignorance, but there arent any rollers actually being manufactured in Vegas are there? I thought they all start in South Afrcia then get shipped to Vegas to get completed. Dont they?
01-07-2010, 09:35 PM
Ron, in the beginning...
01-08-2010, 05:45 AM
MD
HST in Mexico has also been building them for Shelby for quite some time as well. Not sure if HST was a builder from the beginning, but I think they have been doing it quite a bit longer than Hi-Tech in SA.
www.partskeeper.com
01-08-2010, 09:28 AM
Ron, the very early CSX4000's were built in Las Vegas.
01-08-2010, 10:03 AM
OH
It is, and it isn't.
Supposidly, the aspect of the frame that includes the engine and suspension pick-up points are the same. The difference between the fiberglass and aluminum car frames is where the body attaches to the frame. The alumijnum cars have a greater "bird-cage" body supporting frame than the fibergalss cars, where the fiberglass body doesn't need as extensive of a supporting structure.
You can convert a "fiberglass" frame to an alumimnum one by welding on the necessary body supporting subframe.
